Blown headgasket?
Old Jul 2, 2014 | 01:57 PM
Wallj's Avatar
Default Blown headgasket?
So I've been in the process of changing out my clutch in my lt1. While having the transmission out I decided to finally figure out this coolant leak I've been chasing. Well I did a pressure test and noticed bubbling on the rear of my passenger head. So I'm assuming i have a bad head gasket although the car really doesn't smoke or drive bad. Anyway, I ordered some felpro 1074's and intake gaskets. Is there anything else I'm missing that I need before tackling the job?
Old Jul 2, 2014 | 02:28 PM
kris72079's Avatar
Providing the bubbling/leak wasn't coming from the crossover tube (steam tube) banjo bolt, and actually from the head to block mating surface I'd second the gasket assumption. With it bubbling to the outside would precisely explain why it wasn't affecting the drivability. An outward leak from coolant passage to outside of block would not affect anything at all except coolant level. No increase in pressure, no white smoke, no miss. Those would all indicate an inward leak from passage to cyl or cyl to passage. A passage to oil galley or galley to passage leak would show as milky coolant or oil, or both. And yes, leaks often flow one way and not the other.
Old Jul 2, 2014 | 05:59 PM
Wallj's Avatar
Good to know, I had originally thought it was leaking from that banjo bolt but after doing the pressure test and seeing it at the head I knew. That would also explain the drive ability like you said. Luckily i don't have any in the oil or anything like that, just have to keep filling the coolant up. Is it required to change head bolts once they are taken off?
Old Jul 3, 2014 | 10:56 AM
moehorsepower's Avatar
If they are stock bolts, yes, because they are TTY bolts and should not be reused, go ARP..
Old Jul 4, 2014 | 09:53 AM
kris72079's Avatar
^exactly. Torque to yeild is designed to only happen once.
Old Jul 4, 2014 | 02:11 PM
Paul Bell's Avatar
That's MISTER MODERATOR
It wouldn't hurt to have the heads gone through by a local engine shop. I also say go ARP.
