engine compatibilty
Old Jul 30, 2014 | 08:01 PM
Gear Prince's Avatar
Question engine compatibilty
i have a 96 camaro z28 with stock lt1 engine and the engine gone bad, will a 95 camaro lt1 engine bolt right up on my 96? if not what are the mods that has to be done? thanks guys..
Old Jul 30, 2014 | 08:15 PM
myltwon's Avatar
Motors the same both are vented opti cars but pcm is an obd2. Worst case scenario just swap over the necessary sensors and you'll be good.
Old Jul 30, 2014 | 09:45 PM
Camaro_freak's Avatar
The '95 engine won't have a crank position sensor, so you will get misfire codes unless you tune them out. Otherwise you could probably use an OBD1 PCM. Or you could put the timing cover, reluctor wheel, crank position sensor, and hub from the '96 engine on the '95 engine and it should work.
Old Aug 2, 2014 | 08:36 PM
what about a lt1 96 impala ss? does it bolt right up without any mods?
Old Aug 2, 2014 | 08:51 PM
I'm pretty sure it has a different length crank hub, but I'm not aware of any other issues you'd have.
Old Aug 3, 2014 | 12:44 AM
93M6Formula's Avatar
Im pretty sure I answered all these questions in your other thread...
