solid roller cam help please
Old Aug 23, 2014 | 02:47 PM
transam001's Avatar
Default solid roller cam help please
ok i have a 396 stroker with trickflow heads ported out, intake ported. the engine guy said something about a solid roller cam 261/273 at50 688/688 lift 107 lsa. that sounds small cam for that motor. i am running stock pcm so i want to shift around 6800-7000. i have a 4400 stall. flow numbers on the heads were 304 at 700'. i also want to spray a 250 -300 shot. with the cam on a 107 lsa that will only be good to 100-150 shot before it stops making more power on the nitrous? please list some of your numbers or any info would be great, thanks.
Old Aug 23, 2014 | 10:31 PM
96capricemgr's Avatar
If you think that cam sounds small I would ask if you understand the difference between advertised duration and .050 duration.
Far as LSA and that large a nitrous shot, typically yeah you want a wider LSA with that big a shot BUT I would counter with what kind of performance are you looking for?
If the Chassis and motor are decent a 150shot get you DEEP into the 9s.
Old Aug 23, 2014 | 11:13 PM
DeltaElite121's Avatar
Do you have a full flow sheet for your heads? That's definitely a necessary thing to have if you're really trying to maximize your optimization and gains.
Old Aug 24, 2014 | 01:29 AM
Puck's Avatar
That is not what I would call a small cam. With the right heads and intake that cam will make 650hp on a 396 on motor.
Don't see too many 27x exh durations on LT1s - make sure you check PTV VERY CAREFULLY and multiple times during assembly. Of course it depends on your valve open/close timings but my exhaust valve hit with almost 10* less exhaust duration and my intake valve was at the bare minimum. Had to have the pistons flycut.
With a 250+ shot you probably want a cam with less overlap and a wider LSA so you're not blowing the nitrous out the exhaust. Like stated though, with that cam on a 396 and good heads even a 150 shot is going to be a handful.
Old Aug 24, 2014 | 05:07 AM
SS RRR's Avatar
Village Troll
You won't be able to utilize peak power with that cam on a stock PCM. Better to go smaller if you want to go solid roller. I had a Cam Motion 248/250 .650/.610 on a 112lsa and it peaked at 6800rpm. Was perfect for a stock PCM. If my heads were more opened up it would have peaked and plateaued well over the stock rev limit.
Old Aug 24, 2014 | 05:57 AM
This is GROSSLY overstated.
Old Aug 24, 2014 | 02:01 PM
Not every cylinder head is the same, especially on something that has already been modified. That flow sheet (provided it's a comprehensive one and not just numbers at lift) will tell you exactly what those heads are doing. Considering this is a customized build, why would you guess on something so critical like the camshaft? You're leaving a lot on the table that way, particularly on a motor that's designed for running the pill. If you're paying for a cam and have all the necessary information to get it right, it's silly NOT to use that information when it's readily available and he's getting a new cam in the first place.
Old Aug 24, 2014 | 02:30 PM
transam001's Avatar
thanks for the comments guys. i have never ran a solid cam before. some of my friends were over and said thats a small cam, i thought they were nuts, but never running one before i didnt know for sure. yes the engine buider did my heads and has the flow sheet. i am running a stock pcm for now. if i can make a better et on motor and spray less im all for it. comperssion will be 13.1-13.5 with diamond pistons. hope i dont have to have the fly cut. i will be running e85. thanks for all the help i have alot to learn about solid roller set ups. thanks
Old Aug 24, 2014 | 02:53 PM
Solid rollers are great provided you take care of them properly. Get a GOOD set of lifters (we generally recommend Morels) and check your valve lash every now and then and you'll be good to go. There's a lot of fear perpetuated on the internet about solid roller cams. At one point there was a reason to be concerned, but technology has come a long way with parts and hardware so you don't have as many issues like there used to be.
Old Aug 24, 2014 | 03:12 PM
transam001's Avatar
yea people dont understand all the new data they have ,and how they can make better parts. im hoping to get into the 10's on motor
Old Aug 24, 2014 | 04:11 PM
LT1s turn more rpm for a given duration due to the ultra short runner intake. Maybe that is why they thought the cam was "small".
DeltaElite121, the direction I was going is maybe he does NOT need to buy a new cam and should try what he has first.
Flow benches vary so dramatically that they really shouldn't be discussed much but just left as a shop tool. Any good cam guy familiar with the engine type and basics of the cylinder head/intake will be able to spec a cam. If a head plateaus at .630 or .660 it really isn't going to change the cam they are going to spec unless going very high end and having someone develop lobes for you.
What kind of ETs are you chasing, if high 9s are it I would run the cam as is with 100-150shot and see how it does.
That said there is a guy around here running mid 9s on ported LT1 heads, carbed intake and I think a GMPP 847 cam which is hydraulic around 230degrees of duration all on a stock shortblock with some nitrous.
Point being a 300shot on a solid roller 396 if dialed in with a lite car could probably do 8s.
Probably a bit beyond what you were looking for.
Old Aug 24, 2014 | 04:21 PM
transam001's Avatar
yea my car is light, 3300 with me in it. not looking for 8 ,but its kinda like nitrous you start with 100 shot then it gets old so you up it. who knows maybe one day i will want to go 8. 10 on motor, 9 on spray. i am doing a full suspension front to rear. what all that power good for if you just spin and cant hook. you see 1000 hp cars getting killed by 500 hp car that 60' like hell
Old Aug 25, 2014 | 05:36 AM
bufmatmuslepants's Avatar
Fek77k had a 107 lsa in his 396 and said anything over a 100 shot did nothing to improve ET.
Old Aug 26, 2014 | 06:39 AM
moehorsepower's Avatar
First off have you ever even had a 12 second car, saying that cam is small because your friends said so already tells me you know very little to nothing on a performance stand point. I get people that tell me a bone stock LS car is "Scary Fast" then say, I want 1000 HP...I think you better regroup and realize what it takes to get into just the 10 sec zone, 96 is correct..
Old Aug 26, 2014 | 09:33 AM
Puck's Avatar
396 with 300cfm heads, 26x/27x cam, 4400 stall, and 250 shot of nitrous is going to be a hell of a lot to handle - hopefully you did your suspension and cage right!
Old Aug 28, 2014 | 05:37 PM
transam001's Avatar
Yes ive had a 12 second car. Iv been in the mid 11 on a cam and 125 shot. I have never ran a solid roller set up before so i dont know alot. Trying to learn. What i learned from your post is your a jackass who talk **** behind a key board. You said nothing helpful just being a ***. If you dont like it then pm me, just keep your comments to your self. I mean that in the nicest way..
Old Aug 28, 2014 | 09:50 PM
Well then obviously you have others build your motor, the "because my friend told me so"' just states your not sure of a performance build, I was trying to educate you that it takes more than you realize to get into the 10"s and you call me. Jack ***. You kiddo are the jack ***!
Old Aug 28, 2014 | 10:15 PM
BOLO's Avatar
OP, you have some of the best experience LT1 members trying to guide you in the right direction here…moehorsepower,96capricemgr,Puck, just to name a few. I would suggest listening, and do more searching for what you want or trying to do.
As for that cam being too small, theres plenty of LT1's running in 8's on a much smaller cam! SEARCH is your friend.
Old Aug 28, 2014 | 10:35 PM
hrcslam's Avatar
26x/27x and .688" lift, I thought that was HUGE?! Does solid make that much of a difference?
Old Aug 28, 2014 | 10:47 PM
kline454's Avatar
Seems like way to much cam for stock PCM. My old lt1 comb was 262-272 ..675 .675 on a 110. Shifting at 76-7800r rpm 10.6x on motor 9.2s on 300shot. 383 12-1, heads flowed 312@.600
