383 AFR 227 Heads and an F1a @11.5-12psi
#42
I thought the same thing, so I removed the air filter and it didn't pick up one lbs of boost not even a tenth of boost, per the FAST data logger. The AF and power stayed the same as well with the filter off.
I spoke to HOB and ProCharger and they both suggested spinning the blower harder, so that is what I'm goign to try. If this doesn't work I"m really going to be scratching my head as the next place to change things out would be the intercooler and Spearco swears I'm no where near the max capacity. What intercooler are you running
Thanks
Steve
Thanks
Steve
#43
Thanks
Steve
Thanks
Steve
I'm running the ProCharger 1800 A/W intercooler. For the boost level you're making good power, but then if you consider you are on C16 and you have that much timing in it, something is just not adding up. It really seems like since you are spinning the blower so hard it's not making the boost and eating up a lot of drive power. In my opinion if you were to keep your 80 tooth lower and put something like a 48 or 50 up on the blower, it might pick up boost and power. Just my opinion though. If you call Erik at HOB, let him know you talked with me and what I mentioned.
BTW, I LOVE your build, extremely clean and well done! Props!
#44
Thank you I tried to build the nicest LT1 car that I could to try to compete against all the LSx and 03/04 cobras here in Las Vegas. I wanted the car to bruise a few egos but it won’t do **** with 700 hp...
Ill have to look through my email at work to see who I spoke to at HOB. I told them both, ProCharger and HOB the whole situation and they both recommended to spin the blower harder. They said that car is breathing very well. They recommend to run a smaller pulley and to add a few more degrees of timing as well. These numbers are through an auto but I did lock the convertor. I don't know they numbers seem soft to me and this car has always produced good numbers. I was hoping for closer to 800 before I pulled the filter. Where do you think the car should be power
The filter is a (PN#AF059I-001)
#47
1) Check the boost "pre" intercooler. Its as simple as poking a hole in a rubber coupler, and sticking a vacuum nipple in, and connection to your boost gauge port. (that will tell you if you are out of intercooler)
2) Depending on what bypass valve you have, just take it off and plug the hole, and do a mild pull on it. (doesn't have to be to redline) and see if your boost curve still matches.
But yes, the F-1A, will be out of breath right near the redline. So no reason to overspin it, since it won't pick up much.
As far as the removing the filter and not picking up anything, did you remove whatever tubing is connected to it as well? Could it be a tubing restriction? I didn't see what was on the actual blower, just the shot of the filter.
Basically with that trans, a good tune on race fuel/e85/pump gas with Meth, you should be in the 900+ rwhp. (more if it was a stick) If the car can't make it to that mark, then something needs to be looked at such as camshaft issue or something.
BTW: Amazing amazing looking car, and build!
#48
Items to check that are pretty easy.
But yes, the F-1C, will be out of breath right near the redline. So no reason to overspin it, since it won't pick up anything.
The car is an F1A, not an F1C car. When I removed the filter there was nothing on the inlet of the blower just the blower it self so there should have been Zero restriction.
I will test this out this weekend and see what it does. I have the Big Red ProCharger Race bypass valve and the cam specs are below.
The cam was degreed by the shop that assembled the bottom end. They are reputable shop so hopefully it was done correctly. I cant seem to find the build sheet
Bullet racing cam 242/248 112 lsa 626/608 <<- Bullet Racing said this was the best cam to use for the complete combo I gave them every spec they asked for.
Thanks for the help!!
Steve
#51
Thanks
Steve
#52
Sorry about the mistake on the "A" vs "C"
However, looking at your graph again its odd that it doesn't really pick up much power from 5,500 to 6,100rpm (25hp give or take) yet from 4,900-5,500 you gain looks like just shy of 100hp. Seems odd that its falling off in the HP that fast.
Let us know your results of intercooler testing, and what the new pulley gets ya.
Thanks!
Thanks!
#54
Thanks!
Thanks!
What do you think could be the reason of the car falling off up top? I want to take the car to 6500 because that is where it was built to Rev to.
When I went back to look at the log the boost was starting to fall from 12 down to 11 and looked like it was going to continue to fall if I took the car up higher in RPM
Here is the plan:
Blow off valve first, Intercooler testing second, and then I will see where I am. If it is anything more than something obvious it will just have to wait and be dealt with later. I have been patiently and un-patiently waiting for 3years to run this car again
Thanks
Steve
#56
Even when the blower is maxed out, boost doesn't go backwards. If anything it will just stay steady. I feel strong you will find either an issue with the following.
1) To much restriction on the inlet (try running it open blower, no tube, nothing)
2) Intercooler blockage, hits a flow brick wall, and won't flow anymore
3) To much Delta pressure, can't keep Bypass valve closed
4) Last, and I hope not... something blowing valves open, boost going out the tail pipe.
#57
yikes, well that explains why hp stops climbing.
1) to much restriction on the inlet (try running it open blower, no tube, nothing)
i removed the filter and ran it open blower no change
2) intercooler blockage, hits a flow brick wall, and won't flow anymore.
this would suck, i hope it isn't this as it would be a pain to redesign the tubing and setup
3) to much delta pressure, can't keep bypass valve closed
i hope this is the issue as its the easiest to fix!
4) last, and i hope not... Something blowing valves open, boost going out the tail pipe.
the car was very smooth and the valve train was designed to handle the setup by afr along with jessel and bullet racing cams, so i hope they know what they are doing lol
#59
Say you have 10 psi in your manifold. (This 10psi to hold the valve shut)
But you have an intercooler blockage of say 5psi
That means you have 15psi in the tubing from blower to intercooler
(Where the valve is)
So thus the 10psi of pressure in your manifold, can't hold back the 15psi on the valve. (And it cracks open)
These are totally example numbers. But the idea is there, you want to least amount of delta pressure as possible.
#60
What happens if the customer has an intercooler blockage, and the bypass valve before the intercooler is this....
Thanks for dropping in here to help a member out
