96 lt1 crank hub
Old Oct 6, 2014 | 02:15 AM
96lt1Monochromatic's Avatar
Default 96 lt1 crank hub
When I bought my car I noticed it had a very slight wobble on the harmonic balancer. I put a new balancer on and it was the same. I ordered a new crank hub. The auto parts store got it in but it's different than the one I had on there. The one they gave me is round and the one I had was 3 fingered where the bolts thread to the harmonic. The bolt holes match up and the micrometer says it's the same but the new one is keyed. I also have to pull out a roll pin dowel on the new one. Should I install it without a key and just press it in or reorder one that looks exactly like the one I have? Thanks for reading.
Old Oct 6, 2014 | 06:51 AM
94LTZ's Avatar
As long as everything matches up as far a depth it's going in the cover and actual crank size I don't see it causing any issue, my aftermarket hub is round and so far good.
Good luck.
Old Oct 6, 2014 | 11:01 AM
Camaro_freak's Avatar
I installed a powerbond hub for my '96 build and it is also round and keyed like yours. I decided to use a key just to make sure it doesn't spin on me. Should work fine for you either way.
Old Oct 6, 2014 | 01:29 PM
Catmaigne's Avatar
Using the key isn't totally necessary with normal accessories but if it makes you feel better...
Old Oct 6, 2014 | 08:36 PM
Thank you. It worked without a key. I'm going to look up what size key works. Thanks for responding.
Old Oct 6, 2014 | 09:28 PM
94LTZ's Avatar
It's the same size as any other small block Chevy and ace hardware has a assortment of the keys in Stock in the nut and bolt section.
