93 Trans Am times
Travis beat me to the punch, I type slow.
With stock heads and SCR, you generally want to keep the intake duration no more than 225 or so. I would not select the 306 or 292xfi cam for your application, those peak at ~6600rpm and will be relatively lazy under the curve.
The XE 224/236 also works well in a stock engine when ground on a 112 lsa.
You might end up needing to swap injectors due to the fact that 1993 models have 22lb injectors stock. Back when I ran bolt-ons and a 224/236 cam in my stock engine making 355rwhp, my stock 24lb injectors were at 110% duty cycle. If you do swap injectors, all you are going to need is 28s or 30s, max. I think a set of stock 26 or 28lb injectors out of a LS1 or LS6 car would do fine.
