LT1 cam swap?
58mm T/b
FLP full exhaust no cats w/ borla open plate
1.6 Rockers
Comp Cams springs already installed
150 dry shot
also its an A4 with a 3600ish stall....hasn't seen full stall speed cuz the slicks he has start to spin....also a HPIII.....roll cage...etc I know I am leaving things out....
Is there anything special that we should watch out for while performing this swap? Besides the obvious opti spark
Any special tips for us? Cuz it's def our first time....I am the only of of us three who has even done a cam swap ever but then again that was in a 1970 Dart....
Any info would be greatly appreciated as we are starting to tear it down tonight to hopefully have it done by weekend.....
Also....anybody have any opinions on possible gains?
The car right now in full street trim runs 11.56...forgot the mph...on the bottle...keep in mind it is a heavy convertible with a rollcage no less....lol....but possible et improvements? HP gains???? Sorry for the long post but to tell the truth we are all a little nervous about this swap....might take a lot of beers
this will help a little too,
http://www.automotiverebuilder.com/ar/ar99928.htm
Just take your time, it's too easy
You need to get your idle bumped to ~900rpm and a decent tune.. LT4 KM, etc
The stall is probably about perfect.. since the powerband is so much higher with the 306. As far as the opti.. Ive had mine off numerous times, and rebuilt it at 96K. Im at 117K now and the opti outlived the engine thats for sure. As long as your neat, orderly, and keep everything clean..should be really easy. Hope it turns out well.
For the condenser, do as S8E said, pull it and have it recharged. Hell, with 134a, you can do it youself, pick up the kit at any parts store. Too easy.
Sapper- Could we just go with the mail order tune instead for the obd II?
THen block off the hoses. As fast as the harmonic balancer, Make sure you left the center bolt in the crank (screwed in part parts) to push off of. It wont work if you didnt.
air pump..as said ^, unplug, take off, hold on to just in case it throws a code, but make sure you tell Alvin or Bryan if you choose them to do your programming. If it doesn't throw a code....EBAY, some one will buy it, if not, smash it with a big friggin hammer just to pay back the moron who invented it.
