Traction Control Module Removal LT1
To answer all your questions OP, the cruise module is the same between ASR/non-ASR cars. For cruise control to work after removing the module, a non-ASR (or TCS for Pontiac) is necessary. However, your throttle will work absolutely fine with only the throttle cable installed. So yes, you can put it in later.
To get rid of the light associated with unplugging that ugly module, you'll simply need a resistor that matches the resistance of the servo motor. Just measure the resistance of yours and plug a matching resistor into the two pins of the servo harness. IIRC, it was 2.2 ohms on mine, but that was a very long time ago.
