corvette acc bracket work in camaro?
Old Nov 17, 2014 | 02:25 AM
Camaroman94's Avatar
Default corvette acc bracket work in camaro?
Hey all I have a 94 3.4l camaro currently. I had previously bought a 95 9c1 caprice lt1 to swap into my old 89 camaro before it got wrecked. I had bought a corvette acc mounting bracket as to not have to notch the frame on my 89. I am currently about to start swappung in the lt1 into my 94. I am just wondering if the corvette acc mounting bracket will fit and work properly in a 4th gen camaro?
Old Nov 17, 2014 | 02:33 AM
Default 9c1 caprice lt1/t56 swap into 94 3.4L
Hey all I have a 94 3.4l camaro im planning on swapping in a 95 9c1 caprice lt1/97 ss t56 into and was curious what parts will fit/work like stock exhaust manifolds etc. It has the N10 perf exh. Option with dual cats too? I already have the clutch/flywheel assembly etc, will my stock driveshaft work? Im just curious if ill run into any problems? Any help is greatly appreciated
Old Nov 17, 2014 | 06:17 AM
96capricemgr's Avatar
Don't forget to put a pilot bushing in the rear of the crankshaft on the engine.
The Caprice accessory drive will push that stuff I think another 1/4" forward. Otherwise I believe you can ignore the fact it is a b-body sourced engine.
You do understand that 9C1 meant nothing engine wise, not even that the car got an LT1, some 9C1s got the 4.3l that looks just like an LT1.
Old Nov 17, 2014 | 06:27 AM
First, you really should have put this in your other thread.
Do you have the Caprice bracket?
Old Nov 17, 2014 | 07:31 AM
Paul Bell's Avatar
That's MISTER MODERATOR
I agree. Abracadabra! It's all stuck together.
Old Nov 17, 2014 | 03:17 PM
not sure if I still have the Caprice bracket or not, I have a brand new corvette 1 though, and I know a couple things will fit like the alternator, ac compressor....I think I need a power steering pump/idler pulley assembly etc. Can I just bolt or weld on v8 motor mount brackets to yhe v6 k member, or do I need to replace it?
Old Nov 19, 2014 | 11:09 PM
jay7199's Avatar
ill trade you a F-body bracket for the Y-Body bracket?
