exhaust opinions
Old Jan 8, 2015 | 09:52 PM
TravisMcGill2000's Avatar
Default exhaust opinions
Im currently running 1 3/4 stepped to 1 7/8 headers with dynomax bullets right off the headers. Would I gain any power swapping to a 3in x or h pipe? Looking for small things to put my 355 in the 6s na. Thanks
Old Jan 9, 2015 | 10:05 PM
LT1's Avatar
LT1
I think 3 inch is over kill unless your making over 600hp.
Old Jan 9, 2015 | 10:20 PM
On 250 shot I be around 600rwhp.
Old Jan 10, 2015 | 02:50 PM
Catmaigne's Avatar
3" X or a 4" single a la Mufflex would do it.
If you're set on duals then X pipe > H for improved scavenging.
Old Jan 12, 2015 | 11:23 PM
SS MPSTR's Avatar
Old Jan 13, 2015 | 10:37 AM
smitty2919's Avatar
Create a tuned length collector extensions and you may see gains...depending how close your current setup is to a tuned length setup.
I've done this paint test on my 04 GTO with a full y pipe to single 3.5" exhaust. Paint did bubble where it got hot. I then added an H pipe at that location. I have no before/after dyno results to prove if it did anything.
Old Jan 13, 2015 | 11:30 AM
BIGsmokey10's Avatar
Have you tried pulling the bullets off the headers?
In my neighbors 461 olds motor that were only turning 5700 Rpm , it's worth just a hair under a tenth when we take the bullets off versus them on.
Have you looked into a header evacuation kit?
Are you tuning the car yourself?
That tight *** converter ain't helping
Old Jan 13, 2015 | 02:15 PM
I havent tried that yet but I will when I go back to the track. I havent look into a evacuation kit. Do you think it will help? No im not tunning it myself. I have a cable but just worried about missing something up. I need to start learning how to do it. Far as the coverter ive been thinking about swapping it to a 4k+ ptc.
Old Jan 13, 2015 | 04:43 PM
It should pick up no doubt yanking the bullets off... running the evacuation set up will help but very Minimal. Mainly helps with oil control if your for example popping a dipstick out because of excessive crank case pressure . It'll pull a couple inches of vacuum but you got to run open headers for it to be the most efficient.
Your converter is working great. To tight to be na but it's working good with a 1 39 short time. I certainly wouldn't touch it.
Have a few more pounds u can yank out?
To bad you aren't comfortable tuning it. I was going to suggest getting a good oxygenated fuel like ms109 or vp113 . Tuned right over pump gas you'll Ditch them 4/100
Old Jan 13, 2015 | 05:46 PM
Im goin to start lookin into the tunning part. I got some weight to be pulled but goin to be adding some back with s60 im getting. Im curious if a smaller cam would work better on my little 355. What size converter are you running?
Old Jan 13, 2015 | 09:50 PM
Mines around a 4400. 8" mechanical diode. It's a FTI snowman. When I ordered it I had it set up for strictly for a 200 to 250 shot. Haven't sprayed it yet but it's been 1.45 60 ' foot , 6.77 na and letting out 80 feet early. leaving off a dead idle and still tuning it. Hoping for high 6.50s when I get it sorted.
Surprisingly the converter Is very tight and has great street manors. I can't wait to spray it.
Don't touch the cam. .. data log it and go from there. Honestly 1.39 is getting down for a 100 shot. The more information you have like how much rpm does the converter drop ? How much and where is the motor making power? The more info you can give em the more they can get that converter spot on... but judging by your short times and et man I wouldn't touch that thing. Get it out more and run it.
Curious what does that thing weigh
Old Jan 13, 2015 | 09:59 PM
Just to add.. your not going to get a converter that works excellent on motor and excellent on spray. There has to be a compromise somewhere. Can have a killer converter on motor thats nice and loose and spray it and blow threw it, or vice versa and have a tight converter that's Killer on spray but is to tight for motor. .. you can get a converter that is " in between" that works ok on both ends but there has to be a give somewhere. That's what I have been told and have came to agree with it
I mean you dropped almost a tenth and a half from a 100 horse... that's killer. . It should really boogy with some bigger jets in that plate
Old Jan 13, 2015 | 10:39 PM
Weighs 3300 with me in it. I have did any data logging yet. Ive only had it out twice. Track open feb 28th. I guess I really shouldn't worry to much on na time and just focus on the bottle. I really need to get it on the dyno. Its on mail order tune at the moment. Judging by the plugs its little rich. I have appointment to get it dyno tuned next month. Closest tuner is 2.5hrs away
Old Jan 13, 2015 | 10:42 PM
It should go 6.4s on 100 shot. It needs little more timing. Was playing it real safe since im on the mail order tune. I really just started to thread because im looking for little things to change before the tune. Winter is killing me. I got the itch to race and all the tracks are closed lol
Old Jan 14, 2015 | 10:02 AM
Well it should go 6s na with just a tune then. Like I said make a pass with the bullets on and off and check the difference. If you want to spend a little coin bring some oxygenated fuel to thr dyno with you
Old Jan 14, 2015 | 01:05 PM
Thanks I will give it a shot. When y I u gona spray yours?
Old Jan 14, 2015 | 03:23 PM
When it's not -5 out with a foot of snow on the ground lol. Should be early April. My local track lapeer sucks, might go to milan or Norwalk when I spray it.
You got to go to the shootout this year!
Old Jan 14, 2015 | 03:53 PM
Milan seems like a pretty good track. Ive been there couple times. While I was in ann arbor working. Im goin try like hell to go. The issue is I travel with my job. Summer is the busiest time for me.
Old Jan 14, 2015 | 05:22 PM
Summer has to suck in Georgia for the heat.
Milan is a good track. I like going to Norwalk the most. Tracks killer.
The time I made it out this year was at lapeer. I'm very surprised my car hooked lol. When you oil down they drag a tractor tire across the track to spread it out. No bs.
Think you'll make the shootout this year? I've always watched your car while I was building mine. You'd kick *** in espa and esna
Old Jan 14, 2015 | 05:42 PM
My local track was like that. They change owners and they new one is getting it back right. Im making plans to go. Going to put in vacation now. That way I can be off. Bowling green only about 4hrs from my house. So hopefully I will see you there.
