Need help please ABS INOP
www.shbox.com
You should also buy one of these:
the brakes going about 15-20mph, make sure no one is behind you! It sounds silly and unorthodox however, it got rid of my brake light...As for the ABS INOP, mine has done this twice, one time because my third brake light was out (you should check that if you haven't) and the second time was after doing a brake pad swap in the rear, I took the negative battery cable off for 10 minutes, put it back on, the light hasn't been back on since. Hope this helps!
I agree with SS RRR, it sounds like you still have air in the system.
Even with the above(Motive bleeder), I had a slightly soft pedal. I was finally able to solve that problem(by cycling the abs motors several times and bleeding the ABS modulator) when I bought a Tech 1(yes... a Tech 1) off ebay with the correct mass storage cartridges and OBDII adapters.
I didn't ever get an ABS INOP light through that entire process.
For the "brake" light, check your ebrake switch at the console handle(detects if the handle is up or down)....as well as the level being low in the brake master cylinder reservoir. It also could mean a problem with the brake system according to the drivers manual.
Given your ABS INOP light, I suspect the brake light on is a result of whatever is wrong ABS system.
Given that so much has been done to the car and that issue has been there since you bought the car, I think you need to pull the codes for the ABS system to see what the car is flagging as a problem.
To my knowledge, you will need a Tech 1 or 2 tool to do this as the ABS bus resides on a different bus than the PCM/ECM(that is why general code scanners can't pull ABS codes...at least on OBDII cars).
I'm not sure on OBDI cars....I do remember reading that Gary may have a solution to pull ABS codes. It should help in trying to isolate the issue. Could be a bad ABS motor pack, isolation solenoid, wheel speed sensor(that has turned on my ABS INOP light before....had to get new front hub...just replaced both since they were almost 20 years old...wow, that seems so wrong....20 years....), etc.
DTC 45 Right Front ABS Channel Does Not Move
DTC 46 Rear ABS Channel Does Not Move
It could be either the sensors or the input receiving them....
The sensors need to be tested for output. On a tech 1 or 2 tool, when driving, you can view individual wheel speed to see if there is any kind of output from the sensors at all being received.
I'll do a little digging to see if GM suggests another way to test the sensors other than with a tech 1 or 2.
Both ABS codes 45 and 46 are referring to the ABS modulator/motor pack.
There are 3 motors on the ABS modulator, a left front, right front, and one combined for the rears. For some reason, when your right front and rear motors are commanded to go to home on start up, they are not moving(locked up).
This could point to a bad ABS motor pack, seized pistons in the ABS modulator, power or short issues to the wiring of the motor packs.
The EBCM is looking for current feedback from the motors to determine if they are doing the proper movements.
Most of the diagnostics in the GM manual are using a Tech 1 or 2 for the troubleshooting process. Commanding the motors to home, move, etc. It will also tell you the current draw from each motor(I've seen this myself when cycling the motors to purge the ABS modulator of air with my Tech 1).
Here are a couple of iphone photos from my '96 factory manual. Just be aware, that wire numbers and/or colors may be different from another model year. The pictures are big, but I left them that way to zoom in on the text, even though it is a little blurry.
http://www.ace1252.com/1996_Z28_Fact.../ABS_DTC45.JPG
http://www.ace1252.com/1996_Z28_Fact.../ABS_DTC46.JPG
