Front End Wobble
Old Jan 16, 2015 | 06:24 PM
myltwon's Avatar
Default Front End Wobble
Seems like I have a front end wobble while driving at either low cruising speed (<15mph) or decent highway speed (>65mph).
I have 3.5" Prostars on the front and before I tore into it, was wondering what the likelihood it's something besides a bent wheel, and also what else to look for.
Thanks in advance.
Old Jan 16, 2015 | 08:20 PM
nitrous2fast's Avatar
Most skinnys on the front are not for DD.
Old Jan 16, 2015 | 08:54 PM
NewOrleansLT1's Avatar
My car use to make a dribble sound over bumps and just didn't feel solid, come to find out I needed upper a arm bushings, ball joints and a front wheel bearing..
Old Jan 17, 2015 | 01:28 PM
myltwon's Avatar
I understand that, I've had multiple front tires on the skinnies since I've had them on the car for over 6-7 years.
Thanks neworleans I will check those out. The wobble is a side to side vibration rather than up-down.
Old Jan 17, 2015 | 04:52 PM
Jaxem's Avatar
sounds like a wheel bearing
Old Jan 18, 2015 | 11:18 AM
myltwon's Avatar
Alright I'll check into that, along with a balance.
Old Jan 21, 2015 | 09:28 AM
mab6680's Avatar
wheel bearing, or tie rods/ends jack the front up and see if theres play in the tire side to side. there should be very little play
Old Jan 21, 2015 | 05:10 PM
myltwon's Avatar
Thanks for the tip, I'll check that as well!
Old Jan 21, 2015 | 08:21 PM
camar0corey's Avatar
If you end up having to replace anything Moog stuff is way cheaper on rockauto versus the part stores. I rebuilt the whole front end a few years back for $330, parts store price was over $500.
Old Jan 21, 2015 | 09:18 PM
Kevin97ss's Avatar
If it's a radial tire check for a shifted belt.
Old Jan 21, 2015 | 09:33 PM
SS SLP2's Avatar
Bingo ' this man ^^is rite on
jack up the front and slow roll each front tire around, then spin each as fast as possible and watch each tire and you WILL SEE a wobble or not or budge if you do not see anything , as you roll around feel the tire with your hand and you will find the tire which is the problem
Johnny
Old Jan 22, 2015 | 05:01 PM
myltwon's Avatar
Glad people are still responding in here, thanks again for all the advice!
Maybe I'll actually get to it this Saturday
