lt1 question
Old Jan 27, 2015 | 11:33 PM
ZzTeaRs's Avatar
Default lt1 question
Thoughts on how fast a full bolt on Lt 1 will go with 3.73 gears and a 150 progressive shot, a stall and some radials will go .
If I'm not looking at 11s I will be going a difftent route. I'm pretty sure it should be 11s but I ant to make sure lol
Old Jan 28, 2015 | 06:13 AM
bowtienut's Avatar
11's will be a walk in the park if you get everything even close to working right.
My bolt-on 4000 lb car ran consistent 11.3's with the 150 shot and 4.10 gears and a 3400 converter. You're probably 300-400 lbs lighter, and your F-cam should produce a little more power on the spray than mine did.
Old Jan 28, 2015 | 07:24 AM
SS RRR's Avatar
Village Troll
My best friend had a 150 shot on his bolt-on M6 car and was able to run consistent high 10's. I think his best was 10.7. Can't recall the MPH. If you can launch the car effectively you'll easily be in the 10's, IMO.
Old Jan 28, 2015 | 08:06 AM
93M6Formula's Avatar
I don't think i'd even worry about a progressive controller at that power level. If you have the right suspension, you should be able to spray off the line (Above 3K rpms that is).
Old Jan 28, 2015 | 08:49 AM
ZzTeaRs's Avatar
Awesome. I was thinking a progressive shot just to save the rear end some grief.
Old Jan 28, 2015 | 10:50 AM
Honestly you're gonna break that 10 bolt no matter what. Progressive would probably slow down the death though.
Old Jan 28, 2015 | 01:06 PM
ZzTeaRs's Avatar
Just until I can get the new axel money. Then it's game on !. Hoping it will last one season lol
Old Jan 28, 2015 | 01:29 PM
ZzTeaRs's Avatar
Any advice besides leaving soft to help the ten bolt live this season ?
Old Jan 28, 2015 | 01:30 PM
bowtienut's Avatar
Run bias ply slicks rather than radials.
Old Jan 28, 2015 | 01:33 PM
VoyagerCamaro's Avatar
I'm gonna give you the best advice on how to not break your 10 bolt, the best and most simplistic way not to break it would be, don't have traction... I'd start saving up for a 9"
Old Jan 28, 2015 | 01:36 PM
bowtienut's Avatar
and stay very conservative on your stall / STR selection. With nitrous you don't need nearly as much help there as with NA.
Old Jan 28, 2015 | 02:05 PM
ZzTeaRs's Avatar
Future plans would be a s40 . I know it will break more than likely . Just like to postpone it lol
Old Jan 28, 2015 | 02:10 PM
No doubt, lol A friend of mine ran a 96 Trans am, 4.10 gear, slicks, Lt headers open, CAI, and a 75 shot in the 1/8th mile, needless to say after 50 or so passes he didn't even make it 60 feet before the rear end gave up the ghost.
Old Jan 28, 2015 | 02:29 PM
I think you mean S60
That's what I have and I love it. If I break this rearend there is something terribly wrong. 35 spline axles and 9.75" ring gear should handle quite a bit.
Old Jan 28, 2015 | 02:30 PM
Hell I broke mine just taking off from a stoplight under normal throttle lol.
Old Jan 28, 2015 | 03:39 PM
ZzTeaRs's Avatar
Yeah the s60. Don't know where I got 40 from lol. If I do go this route next winter it will be getting a forged bottom end, New rear, built trans and a 300 direct port shot. Should be really fun then
