T56 removal help
Old Feb 5, 2015 | 09:09 PM
camfreak's Avatar
Default T56 removal help
Hi how is it going I pulled the motor and tranny to replace the blown motor I broke the bell housing from the block it moved a bout 2 inches i can not get it to move anymore if someone could help me I woulad appreciate it thanks
Old Feb 5, 2015 | 10:23 PM
Catmaigne's Avatar
Push them back together, grab the clutch fork, and pull it radially outward from the input shaft.
Old Feb 5, 2015 | 10:28 PM
camfreak's Avatar
Ok will try thanks nice looking Camaro by the way
Old Feb 5, 2015 | 11:11 PM
Jaxem's Avatar
Yep, the fork is still on the throwout bearing, if you've been pulling on it too hard, you might have broken the clip on the bearing (I did that a couple weeks ago and had to get a new clutch because of it)
Old Feb 5, 2015 | 11:20 PM
camfreak's Avatar
How did you get it off
Old Feb 6, 2015 | 12:28 AM
Jaxem's Avatar
well, i pulled the thing until i broke off part of the throwout bearing so it all slid out then. Like was said, the right way to do it (now i know, haha) is to pull the fork out away from the tranny
Old Feb 6, 2015 | 09:29 AM
guppymech's Avatar
Check out this post for clutch fork info with pics.
https://ls1tech.com/forums/lt1-lt4-m...l#post18237250
Old Feb 6, 2015 | 02:11 PM
camfreak's Avatar
Got it off had to break it from the bell housing and remove the fork everything looks to be ok
Old Feb 6, 2015 | 03:54 PM
camar0corey's Avatar
Hmm it should have just slid out. Unless I am misreading your post.
Old Feb 6, 2015 | 04:03 PM
camfreak's Avatar
It would not slide I had to remove it didn't notice any damage to the throw out bearing or fork
Old Feb 6, 2015 | 04:52 PM
Spartan7's Avatar
So you're saying your only reason for replacing the clutch was because of the T/O bearing? Because that was definitely not needed.
Old Feb 6, 2015 | 05:10 PM
camfreak's Avatar
Thanks for the help now it's time to put back together and enjoy this thing
Old Feb 6, 2015 | 06:59 PM
Jaxem's Avatar
Not needed, but with as much as a new TO cost, i decided to just get it with a new clutch, since the old clutch had a decent amount of wear on it
Old Feb 7, 2015 | 07:21 PM
camfreak's Avatar
Got motor in now it's just plugging in
