Starting problems code 36
Old Feb 25, 2015 | 07:48 PM
elis94camaro's Avatar
Default Starting problems code 36
Out of 5 attempts it started once and then set the ses light. I then turned it off and tried again for like 4 seconds and it didnt start so I scanned it and got code 36. Is this basically telling me my opti is toast? I changed the opti with a delphi one from ebay about a year ago
Old Feb 26, 2015 | 05:36 AM
shbox's Avatar
Clear the code (to make sure the code is current and not old) and try again. Even with a code 36, the engine should run. A 16 would shut it down. 36 would indicate an opti (or opti harness) related problem for high resolution signals.
Old Feb 26, 2015 | 10:38 AM
The code appeared after it turned on that time. It didn't have any codes prior to that because I checked when I was uploading a tune to it about last week.
