95 LT1 /700r4 trans
Old Mar 2, 2015 | 08:49 AM
jdur1554's Avatar
Default 95 LT1 /700r4 trans
put a 700r4 behind my 95 LT1,used a lokar bracket and cablr,problem is,with detent adjusted to where the trans shifts perfect,im only getting about 1/3 throttle opening,any suggestions?
Old Mar 2, 2015 | 09:20 AM
duh's Avatar
duh
What throttle body are you using? You need one for a 92/93 LT1. Otherwise you're probably using the hook up for the cruise.
