New build
1. would i have to have a tbi or a fuel injection?
2. What modifications do i need to do?
3. How many cross members will i need to change?
4. What wiring harnesses will i need?
anything and everything will be greatly appreciated and i can also keep everyone updated on whats going on as i get into it if you would like.
TBI is Throttle Body Injection and was used from 87-95 on GM trucks and cars. I wouldn't even think of putting it in your car. You don't NEED fuel injection but running a carb requires mods to the cowl to clear any sort of air cleaner assembly. Fuel Injection is the way to go.
Wiring harness, exhaust, transmission, driveshaft, cooling, k-member, etc and that's just to get it to run, not counting any mods you want to do. Unless you really love your car, you would be much further ahead buying an LT1/LS1 car than going to the trouble of swapping a motor in.
K-member is different because of the motor mounts, the trans cross member should be the same unless you swap in a T-56.
The entire engine harness whether LT1 or LS1, whatever motor you choose. Buying a wrecked donor car is probably the only good option so that you have everyting you need. Piecing things together gets spendy.
He also went threw and did alot of work to the suspension and very little to the drive train as far as i can tell. Mainly stiffened the suspension and added a disc brake rear axle to it.
All in all i need something to do and dont mind sinking the money into it. At the point and moment i am more or less building a list of stuff i need to do and or get to do all this.
As far as the trans cross its a standard trans as it sits i know i would more than likely have to get a bell housing but would it bolt to a 350 with out having to change the input shaft?
Most of the work i usually do to vehicles is on diesels or older model diesels and i know what needs work for those, hence the reasons i am asking about the list of needs for this.
...ask me how I know...
http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
If the car looks nice and has real suspension upgrades, then the swap would definitely be worthwhile if you could find engine/trans for a reasonable price. I frequent the u-pull-it yards in my area and it's not that unusual for a v8 car to pop up (although manual will be much trickier). The car will definitely be ragged out with insane mileage but you'll be able to get all of the odds and ends for dirt cheap.
