No start- no spark at coil. Testing procedures
Hi guys. My car is cranking over but will not start. It is not misfiring so I checked to see if there is any spark. There is not any at the plug wire going to the opti.
I read in the Haynes manual that I should check that there is voltage going into the ignition module that is attached to my coil (msd coil). However, the wiring scematic in the manual doesn't match the 4 wires going into the ignition module.
The manual said (white, white/black, pink/black, engine ground; I'd assume black for that).
I'm seeing (white, black, white, pink)
Am I seeing this correctly? The wires are super old and a little dirty. I tried to scrape away the filth to see the colors better.
I checked the coil fuse in the fuse box and it was okay. Car is a 92 y body so it may be slightly different.
Any advice or info would be appreciated. Thanks!
Your post wasn't exactly clear but did you check both sides of the wire leading from the coil to the opti? I have had two of those wires go bad somewhere in the middle and before I knew to look at that it gave me all sorts of headaches.
