cc503 and 26986-16 springs?
After doing driving to a few shows last summer i started to notice the clanking sound all the time and the car would start to chug under load when it normally wouldn't
Took The top end apart and this is what i found
I had originally purchased comp cam 918-16 beehives(whats reccomended on Comps website) and brought them in to my engine shop to have them installed on my heads along with a valve job. The builder their said that he would have to machine the heads for them to fit and recommended 26986-16 which he had laying around instead.
This was my first engine build so i took the advice of the builder and went with what he recommended.
So what my real question is. Did my builder **** me and give me springs that were just on the edge of being compatible and keep the 918-16 beehives for himself?
Bottom is this
http://www.summitracing.com/int/part...3068/overview/
Top is this
with the CC503
and Proform 1.6rr SA
http://www.summitracing.com/int/part...6915/overview/
I had minor dip in oil pressure that was cured with a canton pickup and moroso pan.
You'll need some of the experiences engine guys here chime in as to possible sources of issues.
I'm running PAC1518 springs and didn't have to machine anything....I'm not sure what your builder saw that would make him say the heads needed machining. The PAC1518 is the same footprint as a 918.
Just looking at the spring specs, the 986 appears to be weaker than the 918.
Are the stripes on the main indicative of low oil flow? Cam bearings look fine.
I have not had a look at the rod and crank bearings but suspect that they are fine as well.
This was a fresh build with less then 10,000km assembled two years ago.
The 918 is 372lbs.
The 918s also fit perfectly fine without machining.
The builder is wildly incompetent and caused this damage.
There may also be another factor at play here. Where did the lifters come from? They don't look much different from several that failed for me between 50k and 150k miles on a GM Vortec crate engine (Hecho en Mexico). Very likely the same lifters that you would get as replacement LT1 lifters for a rebuild. Mine failed with a milder ZZ3 cam running sufficient spring pressure and revving to no more than 5500 rpm. I've since replaced them with a set of used LT1 lifters out of a 120k mile motor, and all is fine at 220k.
I've installed a new cc503 with new gmpp ls7 lifters just waiting on my comp cam 918 beehives and I should be back in action. dum( I had already ordered the lifters before I posted here)
Anyone know what the stripes are from on the cam bearings in the video?dum
