plugs
I agree. I have a ez-go golf cart that when I pull the plugs they look like this. I've never had any problems with it though. IIRC AFR recommends the Delco 41-629 plugs for AFR195 heads... Plugs that are interchangeable with the delco plug are, autolite 3923, and accel 0416S, however the accel version from what I've heard is a horrible plug.
Thanks for tha help I need it I'm gonna try to change all plugs tomorrow and get NGK gasket seated plugs part#FR5. Stock#7373 keep comments coming need all tha help I can get LoL !!!!!
Splash fouling usually occurs on an extremely dirty engine. Carbon deposits come off from the piston and splash up on the plug. That's why I said it's odd to happen on a fresh engine, unless the pistons and combustion chamber weren't cleaned properly.
U don't think it could be valve seal leaking??? I thought of that but then again if that was it wouldn't the hole plug be black??? I rebuilt bottom end and had heads pressure tested and milled use same valves they still good maybe heads had carbon on valves ????I cleaned heads best I could ????but block was washed hottank and pistons was spotless ??? May be some old gunk left in Afr heads
