A Little Down About My Numbers
I have a 1997 Camaro A4 with the following mods:
-75,450 miles
-UMI STB
-UMI PHB
-UMI LCA's
-UMI LCA brackets
-UMI DS safety loop
-Racetronix 255 LPH kit
-lingenfelter full CAI
-TB bypass
-10 bolt
-UD pulley
-3in ORY (no mufflers or cats)
-Pacesetter LT's
-Dynosport tune
-Sam Strano springs
-Bilstein SLP shocks
-275/40/17 nitto NT05R's
-373 gears
-TA cover
-full richmond kit for the 10 bolt
Current dyno without a new upgraded tune and no account for my full CAI is 270RWHP and 290RWHP. I feel this is a good bit low for an automatic, hopefully I can get 280RWHP with a tune and my CAI. Doing the racetronix kit as we speak.
-75,450 miles
-UMI STB
-UMI PHB
-UMI LCA's
-UMI LCA brackets
-UMI DS safety loop
-TB bypass
-10 bolt
-UD pulley
-Pacesetter LT's
-Dynosport tune
-Sam Strano springs
-373 gears
-TA cover
The real numbers you should care about are trap speed, et, and weight. Or lap times if you prefer road courses or autox.
Opti, ngk iridium plugs, MSD super conductor wires, new water pump, coil and coil wire.
It's rather easy to make 350+rwhp with stock heads if you pick the right cam, the tune is good and the supporting mods are there.
I've seen multiple A4 cars over 340rwhp "cam-only" as well.
Mine is a M6 car so the numbers will be a bit higher than A4 numbers, but I made 290rwhp/327rwtq with CAI, MAC mid-length headers, O/R pipe, full catback and stock programming.
Next I added cam/springs/rockers and a tune and made 352rwhp/364rwtq. Same dyno. That's a net gain of 62rwhp and 33rwtq. I'd like to see someone post up gains like that by just swapping heads and sticking with the stock cam.
FWIW, later I went with a slightly bigger cam, AI200cc heads and Hooker longtubes I made the numbers in my sig, but that was on a different dyno.
So basically in my experience, doing just a cam will get you about 50% of the power gains and a large majority of the torque gains that doing both heads and a cam will get you. Of course, the cam I went with the first time around makes better torque numbers than almost any other cam I've seen in a stock longblock.
OP, your numbers are in the ballpark since the only mods I see that actually increase power are the exhaust and induction stuff. If it were mine, I'd probably do cam/rockers/springs/tune and a quality torque converter and shift kit next. Check the health of your 4L60E transmission too, as one that isn't happy can affect dyno numbers along with everything else.
Just picked up an 1 LE elbow and slp airfoil last night. Looking at an electric water pump and 1.6 rr's. I've already done the TB bypass; was told not to do a 160 degree stat as I already have my tune set to turn on fans around 160ish. Any other bolt ons your recommend?
Thank!
