vibration at higher speed
I do not think so, go to a open empty parking lot, open your door, lean out and turn sharp at slow speed obviously lol and listen for the snap, my guess is it will be distinctly from the rear. In that case the cover has to come off and spider gears and ring and pinion inspected
You were right I just drove it around a parking lot hanging out of the door and the noise is from the rear. I'll try and pull it apart this week. Hopefully the noise and vibration are related.
Hopefully the rear is fine and you can get by with a fluid change and a couple bottles of additive.
