Replacing Oil Pan/Pump/Pickup
Old May 7, 2015 | 05:43 PM
Zacks94Z's Avatar
Default Replacing Oil Pan/Pump/Pickup
Hey guys, looking to change out my stock oil pan for a Canton Racing Products #074-15-242T. What would you guys recommend replacing the oil pump/pickup with? I was thinking the Melling #689-10555C; but I am unsure as to which pickup to use. Any help would be appreciated!
Old May 7, 2015 | 07:55 PM
Catmaigne's Avatar
That pump is +25% HV and could create problems if your bearing clearances are stock or near stock. Also, the anti-cavitation pumps aren't for street cars. Your hot idle pressure will take a hit. The 10554 is probably what you need. STD volume with a HP spring.
