Electric Water Pump Cooling Issues
the CSR is 30-37 GPM
FWIW I don't have a SC but do have a 383 and have had the Meziere HD on for 16 years now....and I drive in 115 degree Vegas trips. No issues...YMMV
They free up power by doing less work(moving less water) that simple.
Usually adequate, sure, but as we constantly see people buy them with no comprehension of the fac they are adequate and only a cooling "improvement" at idle when the system isn't taxed anyway.
I had a Summit pump on my car for awhile and even at 40F outside the car ran warmer at 75mph than at 35mph. Just a few degrees viewable through datalogging. That is in a Caprice which I bet is a little easier to cool, more open nose, stock vertical radiator, more room behind he radiator for air to flow away.
Electric pumps are a cooling system capacity DOWNGRADE for the sake of reduced parasitic loss and potentially cooldown with the engine off. Which is fine if people would understand that.................
You may even see the same with a mechanical as the intercooler, like a AC cooler in front of a radiator, would impede aka restrict the flow of cooler air on the radiator
assuming your cooling system is functioning properly you could try a fan in front of intercooler and or a higher GPM flow EWP
