LT1 Overheating, SOLVED.
) to find out for sure if overheating is an issue with flogging it for any length of time....but lacking funds at the moment for proper tires/brakes/track time fees $$$.
I can't get it to overheat with street flogging however!
Also I have a 160 stat and fans tuned to come on early FWIW.
Again there's more to it than the water pump. That doesn't change the EWP having less cooling capacity than the mechanical. You obviously don't need the additional capacity.
It seems your ambient temps are comparable to mine. What's your rwhp?
The commotion is about the EWP having limitations. Some don't want to admit that.
FWIW, my daily commute is 110 miles, 75% highway.
Would an EWP work for my daily commute? Absolutely. Would it work for what I want to do to my car? Probably not, I don't want to risk it.
Think about it real hard. One of the guys that posted raised coolant temps on the highway with and EWP in this thread I pointed out that the coolant temps could be dropped while still retaining the EWP. Why would I do that? Why? You think my position on EWP is different than what it really is.
Customers HAVE reported raised coolant temps while cruising on the highway with EWP's. It has happened multiple times. That makes it a fact, not opinion. And THAT shows the cooling capacity limitation of the EWP. Will all EWP users have the same experience? No. It depends on the REST OF THE COOLING SYSTEM and how much power the vehicle is making and what RPM's it's at and the weather the car is driven in. As it's ALL been stated before IN THIS THREAD. READ!
If I decide to make my car a street/strip machine, I'll throw one in.
It's not poor reading comprehension, BMX. It's called actual comprehension. Troubleshooting. You are the guy that replaces the Opti to NOT fix the problem. You tell others to replace the Opti only for it to NOT fix their problem.
Maybe it's hard for you to see a car with such a "complex" and "inferior" part last so much longer than your "simple" and "=win" part. But it's not the only one to go that long nor that many miles.
"(read: mature)" Really dude? Look at your posts here and tell me how much you've matured. That's too funny. Most people of maturity don't do what you have been doing for the past 14 pages. Looks like you got more maturing to do there hoss.
Let's do this. Let's change the tone here. No more personal attacks. I'll stop at least.
You have an EWP and a "running" car right? Data log some stop and go driving then get on the highway for 30 minutes and post it up. Maybe You all can prove my understanding of physics wrong with some real proof that it doesn't happen to ANY EWP car ever at all. Because it doesn't happen to MWP cars......
Displacement has little effect on coolant temp. The more power an engine makes the more heat it will produce. I'm sure that 396 has a lot more power than the 350 he replaced it with. At least that's how I read it.
I care not about comparing two different engines. I'm addressing the exact same car in different driving conditions that have results that are abnormal due to the limitations of the part used.
