MAP2 tune on an OBD1
Old Jul 20, 2015 | 05:47 PM
BlkBird95's Avatar
Default MAP2 tune on an OBD1
I have listen to some of you and realized that my car has a half-*** tune (stock motor, procharged/intercooled, 5psi, delteq, botl-ons). I've found a tuner in the Philly area that is willing to tune the ol' LT1 but was told that due to the car being OBD1, I cannot have an MAP2 or MAP3 tune. Is this true?
Also, is it possible to have multiple tunes on an OBD1 car? Say, if I wanted to play it safe on the street and roll the dice at the track.
Thanks all
Old Jul 20, 2015 | 08:43 PM
englundjd's Avatar
Thanks all
You should be able to use a 2 bar map sensor and tune it. At 5psi i'm not sure its really necessary to go to a 3 bar... or for that matter switch from the factory one.
You cant load more then one tune on a pcm at once. I would suggest a mild tune on one pcm and an aggressive tune on an extra.
Old Jul 21, 2015 | 06:28 AM
moehorsepower's Avatar
Run Fast and Far away from this so called tuner!!!
Old Jul 21, 2015 | 06:34 AM
Shownomercy's Avatar
Man-Crush Warning
You can run a true 2bar OS on an LT1 PCM?
Old Jul 21, 2015 | 11:27 AM
Been doing it since 1997 so, Yup
Old Jul 21, 2015 | 11:52 AM
Man-Crush Warning
I know you can run it as such, but how much PCM fooling is done to get the PCM to see boost?
Granted old, but everything I read says its not a simple, 2bar OS load..
http://www.camaroz28.com/forums/comp...uction-560089/
http://www.camaroz28.com/forums/comp...-500809/page2/
Curious more than anything
Old Jul 21, 2015 | 12:26 PM
SwampWS6's Avatar
Mercy......
What are you using for a 2 bar map? Got a part#?
Old Jul 21, 2015 | 12:28 PM
Man-Crush Warning
No, 3bar MSD thingy.
Old Jul 21, 2015 | 12:31 PM
SwampWS6's Avatar
Any info on it? I guess mine would be different than yours since im on the stock intake?
Old Jul 21, 2015 | 12:47 PM
Man-Crush Warning
Think its this one, but not 100% sure
http://www.summitracing.com/parts/msd-23131/overview/
I think you have to repin factory harness cause the 2bar and up sensors are different pinouts than OEM.
Old Jul 21, 2015 | 03:57 PM
Ive been running 12 lbs of boost since I started back in 97 on a 2 bar map, everyone does not understand what they are doing, what they say to do with a 2 bar is really done on a 1 bar, thats where all of the calculations come in, I use to run a 1 bar with 12 lbs then switched to the 2 bar. I tried to show how I did it and everyone said I was wrong. OK, Ive been running 2 bar up to 15lbs, made 722 rwhp but yea I dont know what Im doing....
Old Jul 22, 2015 | 08:35 AM
Man-Crush Warning
I am not attacking you...
I am honestly curious if its as simple as loading a 2bar OS onto the PCM, or is it a matter of tricking tables etc to make the PCM cooperate with boost levels.
Old Jul 22, 2015 | 10:56 AM
Camaro_freak's Avatar
I've been running with a 1.5 bar tune for 9 years. All the map related tables need to be calculated/tuned.
Old Jul 22, 2015 | 11:17 AM
This was not directed at you, I was just stating how I did it and how long I have been running the setup.
Old Aug 2, 2015 | 10:31 AM
BlkBird95's Avatar
Thanks for all the help. I think I may wait for some cooler weather and track it to see if the car should have more to offer, pending a new tune.
