How do I preload lifters?
Also, when I take the new lifters out of the package and place it on my workbench and stick a pushrod in the top of the lifter I try to push down on the plunger and I cant budge it.
In the past I would take lifters, soak them in a little ATF and push the plunger up and down until the plunger would no longer press in thus "pumping up" the lifter. Then I would install all 16 lifters and when I torqued the rocker not down to "0" lash I would give 1/2 a turn to set the preload. At first the rocker would stay firm pressed on the spring but after a minute or so the lifter would bleed down and the rocker would become loose again confirming that I did no bottom out the lifter plunger and the preload was correct. Then I would move onto the next valve.
My 3 questions are:
1. Why cant I move the plunger on these new lifters?
2. How would I set preload on empty lifters?
3. Why would you NOT pump up lifter prior to install? The all bleed back down to where they want to be well before you start the engine anyway.
I guess I will just drop them in and set preload like I normally would even though they are empty. The resistance I am getting trying to push the plunger in by hand should be enough to determine "0" lash when I torque the rocker nut.
Set preload same for dry or prelubed lifter. Important terms are "base circle" and "zero lash". If u dont have those nailed your not gonna do it right. Zero lash is same whether oil inside lifter or not - the cup hasnt moved down yet at all. If u need to google up a hyd lifter diagram and see for yourself.
Another important item is what lifter your using. Original style hyd lifters use 1/4 to 1 full turn preload. New LS7 lifters take only 1/4 turn preload or less. Again if lifter bottoms out it will move the vlv open - u should look for this.
