95 Z28 severe stuttering under load (with video and tunerpro datalog)
Right. It is not a permanent earth magnet, but is everything an electromagnet is (could be used as one). But, instead of being used as an electromagnet, it is used as a transformer.
I tried to get the car to my garage last night but had to tow it there. It's hard to start, and when it does start, it usually dies within seconds. I made it about ten feet down the street before it died.
I'll keep hoping it's the coil or ICM. I have one of those MSD coils and the original ICM. I'm going with an LTCC setup if it's the opti. I'm getting sick of replacing them.
As I was changing the ignition coil, I noticed one of the connectors on the front of the coil was basically not even connected. I connected it and it started right up. It sounded smooth and strong.
This may not be related to the high RPM misfire I originally had. It might have to do with the stalling issue. I'm going to take it for a drive tonight to see how it behaves. In a perfect world, the car will scream down the highway, we'll see.
I sense sarcasm.
I am so close to having the car running perfectly!
I took the car for a run around the block tonight. There is no more stalling or high RPM stuttering.
I believe the stalling was caused by a loose connection to the coil, and the clogged fuel filter caused the high RPM stutter
Here's what it sounds like now.
Notice the hesitation when I punch it at idle? I made a post a few years ago about this issue, and I never did get around to checking for vacuum leaks. I'll check for vacuum leaks. I don't think the emissions delete was done correctly when I put headers on it years ago.
