water pump shaft seal
same for the opti spark timing cover seal?
oh, and also what about the front crank shaft seal?
thanks a lot.
I was asking about how long the water pump shaft seal will last because I just wanted to know that.
you have nice knowledge in cars SS RRR.
the wp drive seal will last longer if you use new "O" rings on the spline shaft of both WP drive gear and WP spline. Also make sure both splines are clean, not striped as well as the inside of the splined coupler and you use new grease on both splines
if your wp drive gear spline has "wobble" in it due to worn bearings, that will shorten the life of a wp drive seal considerably. People in those cases often chose to go electric WP instead of removing the drive gear assembly itself and replacing it
http://shbox.com/ci/water_pump.jpg
