1995 Impala SS long tubes?
Old Aug 29, 2015 | 04:02 PM
ledzepp3's Avatar
Default 1995 Impala SS long tubes?
I can't seem to find anything anywhere from any decent shop. The only things which show up are either block huggers, or shorties. I was planning on doing headers and a decently mild cam on an Impala I'm about done paying off.
Any suggestions?
Old Aug 29, 2015 | 04:36 PM
96capricemgr's Avatar
Stans headers.
I have a set of 1 3/4" stainless with slip fit collector I should sell. Need custom hookup pipes though.
Old Aug 29, 2015 | 06:03 PM
Catmaigne's Avatar
Summit Racing G9001, 1-5/8 primaries and 3" collectors. $120 painted or $250 coated. The coating isn't worth the extra money though and will start flaking after one winter. I would also cut the flanges and make them slip fit.
Ran them with a universal 2.5 X pipe and Dynomax Super Turbo mufflers dumped before the axle. Cheap setup and made good power. 295rwhp/350rwtq with just bolt ons but I think the dyno was a little generous.
Old Aug 29, 2015 | 06:40 PM
lt1-xjs's Avatar
http://www.clearimageautomotive.com/..._y_headers.php
Old Aug 29, 2015 | 07:56 PM
Coatings will fail and uncoated mild steel will fail as well as be nasty for things in close proximity like Oh say the brake lines.
I have done business with Clear Image and Stan's, and recommend Stan's.
Old Aug 30, 2015 | 04:43 PM
ledzepp3's Avatar
Based on suggestions, I think I'll call up Stan's and go from there! You guys will definitely be seeing me in this section more, I'm happy to join the LTx family!
Old Aug 31, 2015 | 12:21 PM
KW Baraka's Avatar
Originally Posted by ledzepp3
I can't seem to find anything anywhere from any decent shop.......
Well....that's because you're on the wrong forum !
http://www.clearimageautomotive.com/chevy_impala.php
BTW.....unless you have a very aggressive stroker build, you may want to consider a set of Tri-Y's for you 4100 LB Impala. Much better for low-end power than the LT's (Quad-4's).
KW
Old Aug 31, 2015 | 12:24 PM
KW Baraka's Avatar
Originally Posted by Catmaigne
Summit Racing G9001, 1-5/8 primaries and 3" collectors. $120 painted or $250 coated. The coating isn't worth the extra money though and will start flaking after one winter. I would also cut the flanges and make them slip fit.........
Will....not....fit....1994-1996....Impala SS....
KW
Old Aug 31, 2015 | 01:08 PM
Catmaigne's Avatar
KW
??? They are in the Roadmaster right now. Granted, the car doesn't have A/C, an oil cooler, or trans cooler (because T56). But they are in there with plenty of clearance around brake lines, steering shaft, etc. and fit just fine.
Old Aug 31, 2015 | 06:06 PM
Based on mynexperience with 3 different sets of headers on this car I think headers are over benchraced. I think dyno headers vary more than headers that fit a chassis.
Old Aug 31, 2015 | 09:51 PM
lsxdick's Avatar
I had CIAs on my Impala they were pretty nice pieces...took months to get them though.
Old Aug 31, 2015 | 09:59 PM
ledzepp3's Avatar
Tri-Y's are seeming like a better idea in this application. I'd just need to see if those headers will match up to a stock exhaust and go from there with modifications to the car.
