1997 Camaro LT1 Intake Elbow Replacement
The factory intake elbow off my 97 LT1 has torn from the rib that connects into the throttle body.
Which intake elbow replacement should I go for. My factory one has the opti vent air inlet and the resonator tube underneath apart from the IAT sensor.
Which one should I buy, any suggestions? If you do can you guys give me the links.
Thank you
Thank you
