Electric water pump puzzlement
Several automotive waterpump manufacturers have FAQ debunking the dwell time myth and you don't see CSR and Meziere using it as a sales argument.
Roger, yes it was datalogging.
Not to say that you are incorrect, but you simply cannot crumple the word and toss it into the perpetual motion file like it is something that cannot exist.
Comparing data sets from yourself and ****** objectively, since both are at opposite ends of the spectrum should give you something to ponder.
Mass flow is directly related to how well you transfer heat.
Yes, but understand there are two components at work that transfer heat, coolant and air. Increase the flow of coolant through the block and it will run cooler. Increase the flow of coolant through the radiator with out a corresponding increase in air flow will not significantly cool.
What I am suggesting is a transfer of function. Certainly the ewp cannot match the flow of the mechanical beyond a certain rpm. The increased flow of the mechanical removes heat from the engine faster. The decreased flow of the electric allows the airflow to pull more heat from the coolant.
Dwayne (Caprice) says he saw higher temps in data log at speeds at or above 75 mph.
By how many degrees I don't know. 2,5 or 10 degrees. Either way that increase IMHO is nothing of any operational concern. Don't know what temp conditions Caprice was in . Wisconsin in general has lower temps in summer than S. Calif. and Nevada. Yes it does get very hot in Wisconsin, more humid, I lived there for 2 years. Just not desert 110+ heat even at midnight in Vegas
My gauge showed a slight increase under significant outside temps of over 110-115 degrees and I see similar increase on my 4 cyl daily so I contribute those increases more to how fing hot it is outside vs the EWP not moving as much water at 75+ MPH as the mechanical (not saying the EWP flows the same)
If my EWP ran hotter under just normal street driving OR at the track I would have dumped it 17 years ago. It would appear by the gauge it does run hotter at sustained FWY speeds when it is 110+ but on most days where temps are 70-80 degrees, the temp gauge stays the same. Does it actually run a few degrees hotter if I use scan tool? Quite possible but whatever that temp increase is, for me it has not proven to be a issue nor has it induced any "ping" or detonation.
I am pleased with the 17 year 90k mi lifespan of my EWP. Significantly more than the mechanicals I had. If it dies tomorrow I will just put the spare on I have had in the trunk for about 15 years and send the dead one back to Meziere for their $100 rebuild and keep that one in the trunk.
On a side note, At the West Coast Gathering in Vegas this year several B-body owners who drove form several states and even the locals said they were running hotter (it was brutally hot out) and most, if not all, had Mechanical WP's. Outside temp will effect any car especially when it is 110+ out.
This thread is moving away from the OP's mod. I hope he does report actuals once he gets some operational time with is track car.
Will be good to hear from him how his EWP performs under his "race" condition.
Caprice, from my understanding, notes he data log a higher temp at 75mph driving. By how many degrees I don't know but I didn't get the impression by much nor was it "over heating"
But back to the OP's use condition. He has spent time researching and machining the EWP for his track use intent. Will be interesting to hear results. If positive what impact did his mod have vs a off the shelf Meziere. Again I commend his effort in attempting to modify and possibly improve the function of the EWP in his track use condition.
So with a decrease in coolant flow there is an increase in dwell time. More time for the coolant to absorb heat from the source as well as more time to release heat in its slower travel through the radiator. Is it out of the realm of possibility that what you have witnessed is the thermostat closing from excessive heat loss at highway speed?
Thermal expansion is a consideration, but there's less clearance between the piston and the block sleeves, they are two different materials under much more force and heat. Not a big issue there, and certainly not an issue at 200°f in the water pump and .030" clearance.
Belt driven Stewart water pump for LT1's
On a more serious note, thank you for posting that.
You're welcome only took a few minutes to capture and edit.
