Best header gaskets???
Old Oct 21, 2015 | 02:28 PM
mr_adaya's Avatar
Default Best header gaskets???
I have a pair of long tube headers from eBay ( speed engineering ) , any gaskets anyone can recommend?? Thanks!
Old Oct 21, 2015 | 02:37 PM
BMX Dad's Avatar
http://catalog.remflex.com/
No leaks, no re torquing, no worries.
Old Oct 21, 2015 | 03:06 PM
fbody_brian's Avatar
Percy's 66031 Aluminum
No problems with them at all.
Had their carbon gaskets, aluminum are far better.
Old Oct 21, 2015 | 03:16 PM
guppymech's Avatar
Felpro, either 1470 or 1406. Going on 4 years with one set of 1470s with no leaks. The key is to make sure the header flange is flat, true it up with a file if need be.
Old Oct 21, 2015 | 03:22 PM
96LT1Z's Avatar
Cheap D-port Felpros
Jaxem's Avatar
Also using Percy's with no problems so far
Old Oct 21, 2015 | 04:29 PM
350 groundpounder's Avatar
Guppymech, any tips on filing the header flange and checking for straightness? Not trying to thread hijack! Ive heard good things about Percy's.
Old Oct 21, 2015 | 04:44 PM
guppymech's Avatar
350, use the largest double cut file you have and just take a couple passes, if they're not true it will show right up. Your MACs are like my SLP headers with individual flanges. The two center ports on my SLPs were warped from welding and took a fair amount of filing to get them flat. Really makes a difference in how good they seal.
Old Oct 21, 2015 | 05:31 PM
96LT1Z's Avatar
Personally never had good luck with Percy's aluminum gaskets. went through three different pairs.. Felpros I have now are best I've used
Old Oct 21, 2015 | 06:42 PM
lt1-xjs's Avatar
Felpro 1406
Old Oct 21, 2015 | 09:02 PM
mr_adaya's Avatar
Thanks everyone!
Old Oct 24, 2015 | 01:25 PM
camar0corey's Avatar
I killed some Percy's years ago, if you have a bolt come loose or fall out they can cook really quickly.
I have a set of copper gaskets The Merv sent with the motor and headers he shipped me years ago (damn that was 9 YEARS ago ). Wish I had a part number, so far as I figure you can't kill them.
