Fel pro intake gasket
All humor aside, the size of the valves do not dictate the gasket used. It all depends on the cylinder heads you have, and in some instances, the intended intake manifold also plays a part. Also, if your heads have been ported, a gasket with oversized port openings may be required.
Are they aluminum heads and were the seats replaced?
The FelPro paper gaskets with the silicon bead I have seen delaminate if covered with a layer of silicone at install. the gray metal core ones I have never had any trouble with, and the stock plastic ones I have seen compensate for a huge angle difference on a friend's crappily machined 383.
The Felpro gray and stock plastic would be trimmable if the person who saw fit to jamb 2.02 valve in got carried away in the port too.
