help installing headers
Old Jun 10, 2004 | 08:23 PM
warbird27's Avatar
Default Need Help Asap On Headers!!!!
i cant get the passenger side header on. i heard i should unbolt the motormount on that side and jack the engine up 2 inches. is this true? and if it is where do i put the jack at?
Old Jun 10, 2004 | 09:07 PM
RacinLT1's Avatar
you can jack up on the oilpan,use a piece of wood between the jack and pan. we used a cherry picker when we did mine,and lifted the engine 2-3" and it went in.
Old Jun 10, 2004 | 10:34 PM
warbird27's Avatar
Default Need More Help Asap, Egr
i have the header in but now i cant figure how the hell im gonna hook egr up to the header. its lined up but i cant seem to reach back to tighten the nut on the bolt
Old Jun 10, 2004 | 10:47 PM
97'-lt1's Avatar
That's what I ended up doing to be able to get my pass. side in. It's not hard or anything, just something little that takes a little extra time. It will make it slide in so much easier that way...
Old Jun 10, 2004 | 11:19 PM
brandboZ28's Avatar
I always jack the motor up using the jack and wood technique but I place the jack under the front of the tranny pan. It works either way though. It makes more room that most think. :tu:
Old Jun 11, 2004 | 12:42 AM
warbird27's Avatar
nevermind, my buddy got it
Old Jun 11, 2004 | 08:27 AM
Gangly's Avatar
I always crank the motor up by the crank shaft pulley. But whatever floats your boat
Old Jun 11, 2004 | 12:02 PM
96SCTA's Avatar
Thank god for buddies. I know it always seems that when i can not do somthing on my car my friend can. And when he cant do it I can. Its funny how it works out. ....Go bye your friend a beer...
Old Jun 11, 2004 | 05:03 PM
dhdenney's Avatar
Another vote for wood under the oil pan.
Old Jun 11, 2004 | 05:17 PM
warbird27's Avatar
thanks, i have the headers in, it wasn't too bad. but now im having the hardest time lining up the header bolts. my friend and i gave up last night at 1 and im not gonna do anything until sat. im way 2 frustrated with these damn bolts.
Old Jun 11, 2004 | 07:31 PM
brandboZ28's Avatar
The easiest way to get the header bolts to line up on my car was to get the 2 outter most started and work my way in and once I got all of them started, torque them down in sequence.
