Lt1 355 or 383 build
Old Dec 24, 2015 | 08:12 AM
  #41
Nophix's Avatar
Originally Posted by LLave
700hp? All you need is big red spark plug wires and a cold air intake!
And a BIG blue bottle!
Old Dec 24, 2015 | 09:44 AM
  #42
96capricemgr's Avatar
two big blue bottles
Old Dec 24, 2015 | 11:34 AM
  #43
Moochdog's Avatar
I just finished reading what all was said I understand everything is costly for parts and other stuff but it's a process so would a heads and cam swap and long tubes headers to much it's has a 186 thousand miles on it now or should I do a full rebuild since it leaks oil
Old Dec 24, 2015 | 02:57 PM
  #44
BALLSS's Avatar
186k mi on the stock bottom end....and adding H/C is not something I would do without at least doing bearings (rod, crank, cam), cyl hone & new rings and having the rods re-sized with ARP fasteners. This requires a complete motor tear down
The new head and cam mod will tax a 20 year old stock worn motor
Old Dec 27, 2015 | 06:38 PM
  #45
HellTeeOne's Avatar
I would do a rebuild on one with that kind of mileage and do the heads/cam swap at the same time.
