What to expect to the wheels
Hard to say because we don't really know what's been done. We don't know because it really appears that you don't know.
I say get it on a dyno or take it to the track, then decide that you've wasted $4k.
At this point, you are to far along to worry about it. Get it on a dyno with a capable tuner and see how she does.
I say 350whp.
Are you sure the pistons are hypereuctectic Mahles? These engines come with them stock. If they are Mahle Powerpaks (piston + ring sets like all of the ones sold on Summit) then they are 4032 forged and can take a good bit of spray.
If your motor isn't together yet, I'd have a conversation with you head porter about how much he knows LT1 motors versus old small block motors. Porting a set of LT1 heads in the same manner folks commonly ported old-school SBC heads is not the path to success.
The cam isn't what I would have selected, but it's not bad either. If I were in your shoes I'd just install it straight up and run it, see what it does.
The pistons are ok. Research the chamber volume and head gasket thickness you're using and try to get your compression to at least 11:1, preferably higher. 52-54cc chambers with a stock deck height and .026 gasket should get you close to that.
If you think you can handle it, I'd say do it. It's a good skill to have whether you do it professionally or not. Just be ready for any curveballs along the way. Tune SLOWLY so you don't mess anything up so bad you get mechanical failures. Read, read, read, until you understand how everything is tied together. Then experiment, slowly with each perimeter and table. See the results of your work, learn as you go. And you'll get there in a year or less, improving the tune every step of the way.
I like Tunerpro RT, really easy user interface: click and drag 3D graphs. If you get the XDF that Steveo made (the guy who did the $EEHack program), it makes it much easier. Read up on his tuning tips and on the links he provides for more tuning tips.
The info we need from the head guy is:
New seats or stock seats?
What is the valve size intake and exhaust?
Were the heads milled? How much?
Were they ported the whole way through or just port matched?
Did he happen to measure chamber volume?
Did he get flow numbers? If so what is intake and exhaust flow?
What valve springs did he use?
And ask this one gingerly without insulting him, has he done LT1 heads before and what were the results of that build?
From the shortblock guy:
What pistons? Part number, cc, material, ring size (you want stock 1.5/1.5/3mm thin rings)
How much was the block decked?
What size and material rods? Part number or stock?
What head gaskets? Thickness and diameter and part number
What rod bolts? Stock rods resized for ARP bolts, stock replacement bolts, or aftermarket rods with what bolts?
What compression ratio did he aim for?
Your cam is on the small side but would be a good street cam. If the bottom end checks out ok, being with -5cc pistons, 1.5/1.5/3mm rings, and ARP rod bolts, you can adjust the top end to make good power. Power doesn't come from the shortblock, it comes from air in and air out (heads and cam), the bottom end just needs to have the compression, low friction, and strength to survive.
With the head gasket info, piston cc, deck height (piston depth in the hole), and head chamber cc you can calculate compression ratio, and you are aiming for 11-12:1. Stock was 10.4:1, lt4s had 10.8:1, you want a little more than that. If your heads are the weak link, you can either get some other heads, or have these touched up again by someone else. You are shooting for 0.035-0.040 quench, which is distance from the piston face to the head face, so it's piston depth in the hole + head gasket thickness. If he has the pistons at stock 0.02 in the hole and used a 0.054ish head gasket, you are WAY high on quench and low on compression, and $34 victor reinz 0.026 head gaskets can get you closer. If he decked the block 0.010, and you use an 0.026 head gasket you are perfect.
The reason I said DON'T START IT is you need a baseline tune with any aftermarket cam before startup. If you start it and are super rich, you could have fuel go past the rings, dilute the oil, and wipe your bearings and not seat your rings properly, thats how you could lose your $4000. Your cam is off the shelf, and any reputable tuner has probably had that cam come through their shop on the dyno, so if you get a mail order tune for $200, he will send you that tune and it will be close. Then you can download the software and tweak it and learn yourself. You are not sunk, if we can get more detailed information, there are things that can be adjusted to try to reach your 400rwhp goal. If your bottom end, specifically the rod bolts, are up to the task of 7000rpm, you can at worst sell your current cam for $300 and buy a bigger one for $400 and spin it to get your goal. At best, you change your head gaskets to 0.026, get 30lb injectors, a tune, and make 360-390rwhp.
