Personal thoughts on upgrading cam
I dont want to leave any power on the table. Im running E85 and between 15-20lbs of boost.....
Im just wanting it to be more strip friendly than street
If you have the money to burn, get the new cam now, just make sure valve springs are setup for that.
Me personally, I'm not a fan of adding more routine maintenance to a car to squeeze every last ounce out but then again I'm lazy.
After talking to various tuners and cam specialist and MOST agreed that cam was on the small side for my goals. After doing tons of research and asking a lot of questions, I considered swapping the cam. I have been shaving weight in order to hit the goal and to make up for the "smallish" cam.....
3 years of battles with this car, I just want to see it perform well!
I presume this isn't a daily driver and just a weekend toy. If street ability isn't a concern, you could certainly step up your cam, but double check and make sure the rest of the combo you're running will work well. You don't want to suddenly have your torque converter not be matched up well. You certainly could go up into the 230's and pick up some et.
Is time a factor? Are you hoping to have it running by spring or summer? Swapping cams could add to the project time. You could be better off running your current cam for the season, shaking out the car and then swapping the cam next winter if you want a few extra tenths.
The decision is up to you!
Im really battling this issue. One is because the car is already in pieces and now would be the perfect time to make the change. Streetablity is not a huge issue. I work about 20 miles from home and random car shows/meets are really the only driving I'd be doing. I like the idea of having it tuned once rather than getting tuned now then swapping cams then getting it tuned again.
Time is kind of a factor as I'd like to actually drive it this summer. The cam swap would only take me a weekend from dis assembly to re assembly. My springs would put me at a safe limit of about .590 lift which is pretty decent. I also get the 1st restall for free and $50 per additional restall.
My main focus is making a single digit pass and if its possible that my current cam could hinder that, I'd like to change now and not even worry about it until solid roller time.....
