Cam Question
This is assuming the motor is in good health. What's the oil pressure look like at a hot idle, cruise, etc.?
My guess is it is $1500 alone just to R&R the motor then whatever parts & machine work on the motor
with the motor in the car the only thing you could do is just stab a cam and if you had to replace the rod bearings against an un-polished crank. The cam bearings are what is most prone to shiating themselves and those can only be replaced with the motor out of the car.
so it is basically a 50/50 crap shoot on if you can get another 50k mi or it spins a bearing in under 5k mi (or less)
If it were me I would save up $ and get the short block done as just a "freshing rebuild" with new bearings, cyl hone & rings, rods re-sized with ARP fasteners, GM white spring for stock oil pump, new stock timing chain/gears. Send heads off to Lloyd Elliott and have him spec a cam and valve springs. You would then have one solid motor.
I just put a can and springs in my 95 trans am with 220 on the clock
Hes not asking if you can install a cam in an engine with high miles, he is wondering about the possible ill affects and longevity, heck you can install a cam in an engine with 500 miles..Let us know how yours go after you beat on it with the new cam..
I know what he was asking. And I was saying in my opinion. I would do it. As I. I just did it. I am an engine builder. If you do a compression test and a leak Down test. Have no main rattle at cold start and oil pressure is not bad when hot. The amount of miles does not concern me. I Chang the oil add z-max. And beat on it. As for my engine with 220k. When my long bolts for my throttle body nitrous plate come in I will be spraying it with 125 shot wet kit. My cam by the way is Crane HR-296-2s-12-IG. Witch is a nice size cam
