LT1 Boost Build Questions
So I want to do things right from the beginning. I have a '94 T/A. Car runs, but it's no fun being stock. So with that being said I want to build the motor for some decent boost. It will be a daily driver/weekend warrior.
I'd like to be around 650-700whp . I'll be getting a second LT1 to build from the bottom up and then will just swap it into the car once it's ready!
I'm just wondering where to start, what supporting mods I have to get done ? Maybe a good turbo build list from another member!?
Car as it sits:
1994 Trans Am
LT1
SLP intake
LS driveshaft
93 m29 short geared t56
KYB AGX 8 way adjustable shocks
BMR Springs
Any insight is helpful! Budget is not an issue, because I'd like to just do it right the first time and that's it. Now I also don't want to spend $20k on a build.
I also wouldn't be completely against a build for that power that's N/A but from what I've read that would be very difficult with the LT.
Thanks in advance!
I'd still love to see a build list from somebody , like a real nice low compression build for boost to the 6xx hp range or a nasty high compression N/A build that gets as close to that as possible.
A turbo build is great for making power but will take time whether someone fabricates it for you or if you do it yourself. I do believe someone is selling a nice turbo setup on another site that should put you near your goals.
A supercharger setup will be probably the most "plug and play " of all the choices IMO and not require accessory deletion/relocation and cooling systems modifications like a turbo setup.
So now that this has been determined , what direction should I take to building the motor.
Anybody know of a parts list for a similar build that is floating around somewhere? I want to start sourcing these parts so I can have the motor built up ASAP
I am about to be in the same boat, I have a .30 0ver splayed 4 bolt LT1 block on the stand now that I am going to build to the 800 RWHP level in the near future.
Lot of things to consider but first would be the engine build, which is your base. You want all forged internals and many people opt to step up to a 383 stroker since you are buying a new crank anyway. General consensus is that 9.0-9.3 compression still feels pretty good on the street in the lower rpm range, but will allow you to run a decent amount of boost.
I would recommend planning on spending for good heads or professionally ported stock heads.
Plan on spending for a decent set of headers and exhaust system.
After the engine build, you need to upgrade rearend, driveshaft and suspension components--torque arm, rear lower control arms, panhard bar, swaybars.
Do the dual fuel pump conversion from the beginning. The upper side of your goal will put you at the limit if the stock fuel lines and rail, so you might want to consider upgrading there.
If I were starting over with the LT1, I would consider converting to the 24x ignition system offered by EFIconnections or Torqhead. This will allow you to use the LS1 PCM which is better to tune for boost. Your goal puts close to the limit of the LT1 PCM.
Supercharging is a little more bolt on, but there are companies that have turbo kits for the LT1.
That should get you going. PM me if I can be of further help. I'm no expert but have plenty of experience in making all the mistake$ the first time around.
For what it is worth, my car isn't quite what your goal is and is still way too much for the street. I can light up the tires at will in 1st and 2nd. But it sure has been a fun project (never ending), is a whole lot of fun to drive and gets a lot of attention wherever I go.
I am now building an engine for boost and currently have 5500 in pistons, rods, crank, main caps, and some machine work. I still need to get it bored and the assembly balanced.
When I look back to the first build in '02/03 and now, 2 things come to mind.
- #1...I dislike working on my car, hence number #2
- #2...Do not go cheap on this kind of power or you will be doing a lot of #1
At 47 years old I would much prefer to be sitting on my toon drinking beer. But my son gets his license in 3 months, the girl is 2 years out yet, and I want to see both kids run the bird.
If you have a quality local machine shop, get in bed with them and go over your goals. Or, find a reputable builder and get yourself a long block. A D1SC Procharger and even step up to an F1A will get you plenty of air. Then you will need a custom front mount intercooler. Contact my brother Bob for pricing if you are curious on what these superchargers cost.
Jon
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
In the end, you need airflow and fuel... figure out boosted method you want, don't skimp on heads or pistons, and over build the fuel system.
