Looking for Scat forged crank
You can use a crank with counterweights cammed for 5.7" rods with 6" rods but not the other way around because the counterweight would hit the piston at BTC.
4-350-3750-5700-L is the part number for the 5.7" rod, 4340, 383 crank which is the same one I have. Mine had to be set up with stock style balance (int front/ext rear)... I guess the bobweight was too much with a ~630g rod and ~450g piston.
