Cross hatch gone on thrust side. Re-hone/re-ring?
I'm thinking for now put it back together, seal the intake ports well, put catch cans on the PCV lines, or possibly even run a vacuum pump around 10-12" and if I start having issues burning oil/smoking then, pulling the engine at that point? A vacuum setup would help correct?
That's a good question. Would be interesting to see what your piston skirts look like.
Could it be a combination of oil in the cylinder as well as E85 fuel wash? Like I said, most of my injectors were pretty clogged with oil, so if the fuel was dripping in instead of spraying a good pattern, would that have contributed?
