Second Best Clutch for 400 RWHP?
What other clutches have you guys been using that work well for around 400 RWHP on the street? Not looking for a strip oriented clutch. Thanks!
(Would have put this in the drivetrain forum, but it seems pretty LS based in there.)
Great street manners and holds great for a mildly modified engine.
Edit: the McLeod disc p/n is 261571.
Brian
I did some more research and it looks like I might just throw a Competition Clutch Stage 2 (4134-2250) in there for now and get the stock flywheel resurfaced. I do not really plan to bring it to the strip, so it should be fine for the way I drive (for now). If this one dies it will be Street Twin all the way.
I was looking at the Spec clutches and they are a little pricier. I figured it would probably be worth running of their flywheels then too. Once you add all that up you are not far off from Street Twin territory.
Are there any good aftermarket throwout bearings available for a stock style clutch? It sounds like most recent TO bearings do not have the best reputation.
SPEC offers them for around $80 IIRC
I also used the Competition Clutch, it like all the other single disc clutches it died. Mostly because of track use but for just daily driving it should be OK. I would just use the TO bearing that comes with it
Pics showing difference between the standard round top and square top TO bearing
The comp stage 2 is what I currently have. It's a lot more friendly for a daily driver, isn't as aggressive during shifts. It's a bit softer. Again I feel like my gears killed this clutch as well. Lol it didn't take long for it to start acting up. I didn't completely follow break in on it as well so I'm sure that contributed to it as well.
I would say there both good clutches, most of my issues I would say is ignorance of the owner. Haha if I had to buy another one, it will be the 2.5 again. I feel it handled the downshifts and more aggressive driving better especially when it got hot.
I also plan on putting in a set of 3.90 gears since my rear end is noisy and leaking, so that should help either clutch out.
I am currently working on getting the motor rebuilt so I am just going the most economical route on the clutch and rear for now to get it road worthy. If I am super happy with the motor and decide to hang on to the car for a long time, I'll probably do the Street Twin and 9" down the road.
Stage 2 is slipping during shifts and downshifts. I feel it just wasn't up to the task of even just an mild Le1 setup.
I found I could adjust my engagement technique to minimize the chatter but engagement was...."prompt". Not ideal in stop/go traffic
That's the trade off with ceramic or Kevlar puc type discs. They hold more power but give up street manners.
Nice thing about the McLeod twin with organic full face disc is it engages like stock but holds way better than a puc single disc. Has about twice the friction surface as a single disc clutch
