94 lt1 smokes when revving?!??
I got a 94 lt1 camaro, 135k miles. Auto. I drive the car maybe Once a week. An only maybe 15 miles. Occasionally ill drive it to my parents place witch is about 40 miles one way. (Let her stretch her legs) anyway I got a sweet deal on it (hopfully) so I couldnt pass it up. When I bought the car it ran weird. As if it wasnt getting enough fuel or it was being choked out...anything more then a hair on the throttle an it would fall on its face. I had no other option to get it home other then to drive it how it was an pray I would make it home before I did any real harm to the motor. The drive was awful, i couldnt get the car up past 50mph an at times, it would drop to 35mph an there was nothing i could do beside feather the peddle enough to slowly build speed back up. Come to find out it had a clogged cat. I cut the cat off an replaced it with a peice of pipe. Fired the car up an boy did she scream then. An to this day runs very good an has very good throttle response. And has very good power still. Same as my other lt1s I had. But regardless if the motor is hot or cold, when I rev it up to even 2500-3000rpms it blows out white smoke. An really blows out thick white smoke when I rev it up to 5500-6k rpms. The car runs damn good an acts as if nothings wrong with it. I didnt think nothing of it, figuring it was just all that stuff in the manifolds an exhaust that built up from havibg a clogged cat. Figured after I drove it a couple hand ful of times an maybe took it out an ran it a little hard to help clean her pipes it would stop smoking. Well 3 months has went by an it still smokes way more then what im comfortable with. Id like to think I know quite abit about cars to sorta determine what I may or may have not done to the car. Im thinking I or previous owner fried the rings. Or it needs valve seals. But im kinda iffy on the valve seals bc as I said, it smokes hot or cold. I want to figur this out fast as to summer is coming an i dont want to spend all summer working on it. Thats what ill do next winter lol. Any insight will be very appreciated!
You already stated your cats were bad. Melting cats doesn't happen due to age - it happens because something melted them. Usually, its a result of too much fuel being pushed into them and then the cats burn it and melt in the process. Find the reason they melted in the first place and I bet that will also address your running issues
Figure out if it is smoke or steam. That's where your problem is. The melted converter is a symptom of your issue. Its not the cause.
Did you open the rad cap and check coolant level?
This is a cold start. An ive checked the coolant today after droving it home from work. (About a 20 min drive home small highway) the coolant is still full. I checked my oil, oil is low but still looks clean. (Not even 100 miles on the oil change) I put a rag over one tail pipe an then smelled it, sorta just smells like exhaust... ive noticed today after its warmed up, it dont do it AS bad but still smokes when reving it up. Also, today when reving it up while it was warm, around 5600-5900 is pops. Like a cough...or maybe like spitting back up thru the motor....
I'd do a compression test, and a leakdown test, and then maybe buy/borrow one of these. They work pretty well. I've had one in my box for years and used it exactly twice. Worth every penny when I needed it. Pull a scan and see what the O2's are up to - they'll tell you a lot as well
We can agree to disagree on this point, then. When coolant is introduced to the combustion chamber, since it is mostly water, it turns to steam. Since people commonly refer to this steam as smoke, your mechanic won't correct you, but I will. Rest assured - its STEAM and easily identified by either the sweet smell, or the way it dissipates in the air. Since its steam. Not smoke. White smoke is unburned fuel being ignited in the exhaust - beyond the point of making black smoke from an overly rich mix (or if you have a diesel - its dumping in diesel). Note - if this were happening on a GAS car, the fumes would burn your eyes. Its not common, but it does happen. White/blue smoke is oil. Black smoke is a sign of a too-rich mix
