1 7/8" Headers for LT1 Engines
The price would be about the same as the LS1 Headers in Stainless Steel.
It would require 1/2 deposit before Kooks would start building the headers.
It would be around September before the Headers would be available to the public and those that paid 1/2 now would pay the other 1/2 before shipment.
There is a minimum of 25 orders we need to get this ball rolling and get the headers and jig complete.
Anyone interested in this should reply to this poll ASAP. On friday we will determine if there is enough response to continue with this.
Thank You,
More Performance Inc.
P.S>A spread port version would be nice too
1) dual Air Injector fittings, EGR fitting & dual 02 sensor bungs for the price?
2) Is the #1 primary going to be a slip-fit like Hooker/JetHot?
3) What gauge steel on the primaries, collector flanges & also where they bolt to the heads?
Thanks,
Dave
ideally I would run a stepped or tri- y($$$$$$$) header to keep torque and still maintain good upper rpm power on a smaller cube motor..If your running a real loose converter and steep gears the hedmans will prolly be best premade header, unless the thread starter here has any comment on what they are contemplating.....the large primary will free up topend,you will just have to play with collector length to get some back pressure in the engine so bottom end torque doesnt suffer..
