To Shim or Not to Shim?
Old May 1, 2016 | 11:59 AM
myltwon's Avatar
Default To Shim or Not to Shim?
Just finished installing my new FTI converter and noticed there is around an 1/8" of gap between the converter pads and the flexplate. Never really paid attention to it with my old converter. Whats the consensus on running washers between the converter pads and the flexplate to "shim" it vesus just tightening the converter against the flexplate?
Old May 1, 2016 | 01:35 PM
hrcslam's Avatar
The converter slides on the input shaft. As long as the tabs are engaged (they are about 1/2 inch long) and it's not leaking, tighten the bolts.
Old May 1, 2016 | 02:12 PM
kris72079's Avatar
If you read the installation instructions you should see that shimming to a certain extent is a normal installation procedure.
Old May 1, 2016 | 02:20 PM
98CayenneT/A's Avatar
At a 1/8 gap do not shim it. That is perfect. Put the bolts in and in turn will pull the tabs against the flex plate. The converter needs to be pulled away from the pump a bit to allow for flex, in turn not taking out the pump binding and pushing the pump inward
Old May 1, 2016 | 03:23 PM
myltwon's Avatar
I understand shimming is normal to do, was just curious as to what the opinion of it was.
Thanks for all the responses.
