CC 981 Valve Springs
Thanlks
I would look into another spring
I ran those springs years ago on a H/C 350 with a mild cam. Had 10 degree locks/retainers.
Since you have them they would "work", just not what most would run today given other choices
Fortunately there are good spring choices now where you don't have to do that.
The dual 987's, yes you do have to. At the very least do the guides as the inner spring will hit the valve stem seal. If you don't grind down the spring pockets the installed height would then be 1.75x so the open and seat pressure would be more than spec for the 987's installed at a shorter height. Depending on the lift of the cam you could be at or close to coil bind so you would have to check for that
