IAC, idle to high.
at 1100 RPM emission testing may not pass if that is what you meant by "inspected".
Every time you clear codes you need to have several drive cycles for the IM monitors to reset. PIA. I had my tuner make mine always read "ready" to get around that issue
If so he killed it. Do NOT push or pull on it, just spray it off with cleaner...but your new one will be clean so just install it. Do th e"reset" procedure for IAC when motor warms up. Hopefully your high idle is just a faulty IAC.
By chance did you mess with the throttle body stop screw. The right answer is no. If yes meaning someone turned it to raise the idle for some reason that would need to be set back to stock position. There is a reason why a TB gasket actually covers the access port to that stop screw :-)
but the new one will be here soon! I really hope that's it... I still haven't found a vacuum leak. Could a faulty 02 cause a high idle? Even though I haven't gotten an 02 code, just wandering.
