93 LT1 no start, possibly opti?
After this we pulled the t-stat and ran flush through the system. When we did this the car ran like crap; wouldn't idle at all, I had to hold it at 1k rpm with the throttle to run the flush through. We had to lay on top the engine though to get the heater hoses up by the firewall, so I was worried we may have bumped a connection somewhere. This was last sunday. Fast forward to today, we go over everything one more time, all looks good and connected. We fill/bleed the cooling system again, accidentally made a little mess again with the bleeder spilling more coolant out than I was expecting. Start the car and it runs rough for about 45 seconds then dies. Now it won't start again. It cranks over, and sputters a little, like it's firing a couple times, but it won't completely start.
Does this sound like we fried the opti? It did have coolant on it when we crawled underneath. Other possible culprits? The fuel pump does prime when you turn the key.
Next I followed shoebox's instructions to test the ignition at the ICM connector. A and D have 11-12 volts dc as they should. B reads 2.5 volts ac when cranking which is in the range it should be if the opti is working. Lastly C reads 0.3 ohms when off, which should be good I would think.
http://shbox.com/1/4th_gen_tech2.html#opti_test
So now I'm more lost. The rough idle we experienced the time we ran it before the time it died still makes me think opti, but this makes me think maybe ICM?
