Best head, intake, timing gasket?
IMHO I have always used FelPro gaskets
I assume you or builder spec the head gasket thickness. FelPro, Victor-Reinz make various thickness. The "GM" Impala head gasket is .026
The FelPro "printo" line is the one for the intake gasket
TC gasket seal kit is around $12
If you are running the the stock water pump, this timing chain set is pretty good for the money.
http://www.summitracing.com/parts/clo-c-3039
Felpro is what i use. If going with electric water pump get a cloyes timing set. Doesnt hurt to have a double roller, just grind down inside of timing cover with a flap disk or something like that. Mine took minor clearancing by crank seal
Yeah a single true roller sounds good. A double roller scares me. I have heard of ppl not clearancing the timing cover properly and having metal shavings from the double roller scraping it and ruining the motor yikes! I like plug and play because this is my first lt1 build. I dont want to F something up! I want to get rid of that water pump drive gear too! Ewp is going on.
